- 22 Jan 2014
No problem mate.
If you're going to spend £650 on a TV - i think you'd be better off going for something like a KS7000. I had a quick search for you, found it for £789 here. So £139 difference.
https://www.hificonfidential.co.uk/...ung-ue49ks7000-49-4k-quantum-dot-suhd-flat-tv
You're going to have a TV then you won't need to upgrade for a significant amount of time and all the enjoyment of a HDR experience for not that much more money.
If you're completely stuck at £650 odd, can't spend a penny more. I'd recommend the H55M7000 - it's pretty much the best non certified TV / not proper HDR. If you hunt around you can get it for £620 or so. If you need something at 49/50" - not sure, i'd have to have a look around.
I'd go for the KS7000 all day long though![]()
Cheers again Sprite.
I'm not stuck at £650, just I started out looking at £400
My issue with the hisense is the 55 inch screen as that's just too large for the wall it's going on.
Thank you also for the Hificonfidential Sammy link - I'm thinking the 6 year warranty + 10 year screen burn warranty with richersounds may be worth the extra £60 over Hificonfidential, as they charge an extra £60 for a five year warranty. I don't usually buy into that sort of thing, but with a big telly like this, it seems like it may be needed...but it could be their marketing just getting to me.
