A few months ago I tried to keep my SH2AC with the 300Mb service but as much as they tried they couldn't get it to work; it turned out the only profiles for 300Mb and 200Mb Gamer are for the SH3.Yes I upgraded from 200Mb to 200Mb Gamer. You will probably be sent a hub3 unless you've strictly stated you want to keep the hub 2. I'd recommend keeping the hub 2...
I won't be upgrading my speed for a long time now, 200Mb is plenty for now. So 2AC will remain until VM have a new hub out that doesn't use Puma 6.
Can you confirm 100% that you have your 200Mb GAMER working with the SH2AC? I called today and spoke to the 'real' broadband tech in Swansea and was told that the 200Mb Gamer won't work with the SH2AC as there are no profiles for it.
Guess what turned up today?
2AC is in limp mode whilst it downloads the latest software, but should be all good after that.
I'm looking forward to seeing my BQM tomorrow compared to the Hub 3
I never had modem mode disconnections on the SH3, my issue was the latency spikes.
Note though, that both SH2 and SH3 will disconnect/reconnect to the internet numerous times for the first 30-60 mins. I believe this is normal and part of the internal "software update" it does in that time.
Both, the latency spikes are there no matter what on the SH3.
Many thanks for that Mrk. Did you just hang on to your old SH2AC? Unforutnately I gave mine back as I had 300Mb at the time and VM don't have them on the books anymore. My only hope I suspect is getting an engineer to come out to replace the SH3 with another SH3 and seeing if he has a SH2AC on the van.I'm assuming all is well going by a few things:...
Here is a comparison of my latency since getting the 2AC installed compared to the SH3. Take note of the quiet times such as 12am to 10am in particular and ignore the busy times as my connection does get used quite heavily...
Hmm, who is this complaints guy you speak of?Nope I binned the SH2 (mine was a non AC), so they ordered me a new 2AC.
Funny because the people on the support line said they don't stock any 2ACs as they were all replaced by SH3, yet the complaints dept guy directly ordered me a 2AC and just said they should send a 2AC but might send another SH3 thinking it was an error.
I'm interested to test my connection out now.
Do I have to sign up for an account for that? And also how long before I would have data to view?
Yes you have to create an account (free)
Data appears in near real time
Don't forget to allow your router to respond to pings![]()
What setting is that under?
