*** AMD "Zen" thread (inc AM4/APU discussion) ***
Guys on the discussion about the Zen pricing here made an observation about the leaked AOTS image posted there and the 6950X 4ghz Kaapstad has sharing his results in that game.
If the latest leak of the 4ghz ryzen are true (final product with SenseMI on), then the Ryzen at 4ghz is 10% slower than the 6950X at same speed, while having 25% less cores............
And given that all AMD comparison info we had against the 6900k were with SenseMI off, means that it trashes the 6900k by a hefty margin, let alone the kaby lake having half the cores.
The AOTS benchmark is very easily doctored. its further back in this thread if you wish to see how easily. I don't think its reliable.
humbug;30485280 said:
Don't care, i have Windows 10, 7 is old slow and buggy.... sorry, lots of 7 fans but its past it!
Far from past it
7 is still the best for audio production use with much lower DPC than 10
7 also feels a lot more responsive than 10 on desktop web use ect
As for gaming there about the same on dx 11 ect
but until dx 12 springs to life then yes 10 has the advantage
Lets not get started about the whole 10 spy os ware
I am not happy about the latest cpu's not supported by M$ in 7..
Journey;30486436 said:
There are at least three prices online from etailers showing inc. VAT prices as of this morning, but obviously no stock since it's not out until the 28th onwards.
its a common trick for retailers to do the imaginary pricing to get people to their site.see the price when they in stock ;)
then you will see how much they really cost.
also aots is a amd game.literally their benchmark tool so throw that in the bin for a start.
What's with the winky smile, after almost every post to do with the price?
I've taken a screen shot, of the prices now, and will do a comparison on release, if they are the same or less you can go buy a hat then eat it. :)
will do.as pointed out how many have in stock ? ask gibbo its a common trick to get people to visit your shop site.google any pc part you will get some stupid prices and guess what they will be magically out of stock on that very item.
if the prices are bang on then they are slower than intel counter parts.
if the amd chips are faster than intel cpus they will magically jump up.
its that simple.
im excited either way.i will probably get one just for media center and to have a mess around with.seeing as i had amd cpus since 1990s lol.
its that simple.
I think you are missing the point, there cannot be any stock as then are not released yet. As for the sites showing stock looking for traffic I find that hard to believe since they are primarily re-sellers and etailing is secondary for the general public.
If supply is good, and the product is good, then the price will be steady, on the other hand if the product is better than expected, and they have stock levels like Nvidia did on the 1080 release then let the gouging commence. :)
its that simple.
No 3'rd option eh? that would be unthinkable, sacrilegious! :D
Thats the thing - so many full sized motherboards and not ONE mini-ITX one.
Seriously,Intel has nothing they can do about a Ryzen 8C/16T CPU in a mini-ITX system.
Intel has far more leeway to adjust prices,etc to target Ryzen in normal ATX systems.
The socket 2011 mini-ITX motherboards are rare,expensive and probably more difficult to engineer than their socket 1151 counterparts.
Ryzen being an SOC means its perfect for a mini-ITX motherboard - not only for an SFF gaming PC,but for things like a compact server,a system for virtualisation,etc.
Why AMD,why do you do such things?? Such a missed opportunity.
Edit!!
Thats the thing - any platform advantages X99 has over AM4 won't be that useful in a mini-ITX system either,ie,more PCI-E lanes,or SATA ports,etc.
This has nothing to do with AMD. Vendors are pouring a certain amount of resources into a platform in its infancy. SKUs such as this (ITX) simply take a back seat. So your distain at the lack of availability at launch is misdirected, if anything. You can expect some teething issues as it is.
Also, Asrock have an ITX SKU for X99 which you can pair with a 10 core part. So &#8220;nothing they can do&#8221; is typically melodramatic.
Furthermore;
1) The Asrock board is inexpensive compared to other boards in the line-up.
2) It has nothing to do with the engineering aspect being &#8220;more difficult&#8221; as to why there are few.
3) Vendors simply don&#8217;t see the value in a mini ITX workstation (given you also lose 2 memory channels also in the case of Intel&#8217;s platform).
4) Given the shorter signal trace and power plane, performance is generally at a marginal advantage in some areas. There simply isn&#8217;t enough call for that SKU on the X99 platform. Hence the lack of availability.
Also,a 4.2GHZ Ryzen SKU spotted in China:
https://www.guru3d.com/news-story/am...libility.html?
Its priced at $290.
Edit!!
I wonder if that is the top bin 6C/12T SKU??
4/8. The P/N and listings leaked represent the dynamic boost clock.
I've nabbed a couple sticks of the avexir ram in the sale, suspect it will be a while before we see ram this cheap again.
My basket at Overclockers UK:
&#8226; 1 x Avexir Core White Series 32GB (2x16GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit (AVD4UZ124001616G-= £149.99
Total: £158.69
(includes shipping: £8.70)
Hopefully ryzen is good and ITX motherboards aren't far behind, otherwise these are going to be sitting on the shelf for a while
Buying memory kits now for an infant platform that is yet to appear is ill-advised. There is no public available documentation for memory kit validation, plus you obviously don&#8217;t know what motherboard you will purchase yet.
So as long as OCUK have no issues with you returning it on that basis if it doesn&#8217;t work&#8230;
AMD compared Zen with Intel&#8217;s 14 nm generation CPU. Zen is also a 14 nm process, but the process feature size is very different from Intel 14 nm. Intel is as small as 89% for CPP (Contacted Poly Pitch) with gate spacing and 81% for 1 x Metal Pitch showing wire spacing. In other words, the Intel process is more dense. Even for SRAM cell size, Intel is as small as 72%. Nonetheless, the cluster size of 4 CPU cores and 8 MB L3 cache is as small as 44 square mm for Intel&#8217;s 49 square mm. There are reasons such as small floating point arithmetic unit, but it is also suggested that AMD has lower design complexity.
At ISSCC AMD has also released first die shot of quad-core Zen CPU, so have a look at those slides: Source VideocardZ
There are a few take-aways worth noting that I&#8217;m guessing people here won&#8217;t spot in amongst all their excitement. Per-core frequency and voltage control for instance; Something that might be worth investing time dialling in on the higher core SKUs.
But even at this level, most users have trouble dialling in a single voltage. Which is why it&#8217;s never really mentioned as being an option on BWE or KBL (even though it is).
Point being really, these slides are meaningless to most here. Performance is what matters, and you won&#8217;t have to wait long to find out&#8230;
It looks like the TDP is higher on the 1700X too 65w vs 95w. That seems like a big jump just for 100Mhz so I wonder if they simply clock better.
Correct, the figure represents the dynamic turbo frequency. The concurrent voltage scaling is what results in the greater power draw. Pretty self-evident to anyone that understands the relationship. I won&#8217;t comment too much again on the overclocking range, just don&#8217;t go expecting too much.
(Names removed to avoid any distress on the playground, happy hunting!)
Legend;30486520 said:
At this point benchmarks can't come soon enough. Anyone concerned the price indicates performance may not be there haha ;)?! We have been brainwashed by Intel in to thinking high price = top performance :D. Please save us AMD!
give it another week and benchs will start showing.
the performance of Rzen is easy to pinpoint, 40% better ipc than FX Series, and lower performance per clock of skylake, the window is pretty small.
and yea intel went nuts since they had the monopoly, stupid markket segmentation, with completly random pricing, where the price doesn't remotly reflect the value added "you dont want to pay 100$ more then tada we wont let you overclock it, you dont want to pay double the price then we will disable Hthreading, it actualy does cost us money to disable built in stuff, but we dont care, cuz what you gonna do ? buy an FX cpu hahaha "
So your adamant that those 4.0 / 4.2 figures are boost clock figures? even though the retailers listing them show base clock for Intel CPU's? but chose to show boost clock for AMD i guess to show them in a better light?
And your also adamant that the RyZen CPU's wont clock much over 4.0ghz, so effectively if they are boosting to 4.0ghz we cant expect to push them further than say 4.2/4.3?
Not interested in your veiled insults in your above post pretty much calling people reading this thread ignorant noobs, as its pretty much your standard attitude lol.
I do hope for your sake your right, as if you are wrong... well... pretty big egg on your face :(
Depends on what SKU you're talking about as to how far you can push. 8/16 4.2 benchable 4.1 max unconditionally may be possible with the right cooling. 4Ghz is achievable on air as I've said already.
I'm always right, that's why I make so much dollar! :D
LOL seriously... just wow ;)
yeah, I'm not worried, :) while true that AM4 is in its infancy and we don't have anything validated as of yet, DDR4 is pretty well established, and seems like it would be a pretty big **** up if they haven't got fairly broad coverage, and hey, worst case scenario I stick it in a Intel system down the line or sell it on.
You were wrong about 2.8Ghz being near the limit as we are now over 4Ghz
You were also wrong about 2666Mhz limits.
Now you have changed your tune to 4.2Ghz being the limit, why should anyone believe you are not again just trying to troll people?
Dis gun be gud! ;)
Seriously though, dont provoke him, he will just come and drag you down to his level of moronicness and beat you with his vast experience :(
Lets keep it on the topic of AMD and Ryzen and the fact the CPU market is about to get a much needed shake up which should hopefully benefit us all!
As usual Humbug, I think you're confused. I never once said anything about 2.8Ghz. So unless you can show me where this was posted...
You really should pay attention to a few things I post, you might learn something! That comment applies to far more than just pre-release information. :).
Regarding memory; 2400-2666Mhz is still the recommended range band for memory for P&P.
SiDeards73;30487082 said:
Dis gun be gud! ;)
Seriously though, dont provoke him, he will just come and drag you down to his level of moroseness and beat you with his vast experience :(
The word is moronity, that you were struggling to find there lol
