niro750;30488054 said:I just put all those shades in my basket to do the same style earlier then I come here and boom haha, don't think I'm copying when I do mine!
Same problem for me, but I'm months away so it's all good
it's a nice more subtle combo isn't it - played with the idea of a colour accent but with the amount of copper it's just not needed. One thing I do dislike is the cable combs, way to wide compared to some of the tighter 8 way ones I've got.
Cenedd;30491350 said:Nice. You could always try the lighter shade between the black and grey - 4th in from each end to give 3B/1P/4G/1P/3B (where B=black, P=platinum, G=grey).
Looking good with that stripped down board. Much classier![]()
I think you may need to make it clearer in your instructions when to stop repeating step 1 and move onto step 2!![]()
That's shocking the ATX jumper was wired wrong. Good job it wasn't sending power somewhere dangerous!
Fittings are looking good as are the fans. GPU cables look good and nice that the ATX cable echoes that.
So yeah, if you ever buy extensions/adapters etc from anybody always check they are wired correctly. I would surmise that the person who is far worse off than you who has to spend twelve hours a day making them can make mistakes..
Rig is looking stunning fella.
Yeah I should have checked to be fair I'm just lazy
Currently humpty is back together again so sat here while Dr. Drop is a stable 8PSI thinking about getting the wet stuff out...
I promise to be very gentle when I cut it in half for my non-sli setup
