You can always shove a Dr Drop on it. Up to 8.7 psi (0.6 bar) of test pressure with a working one (hint: mine isn't). Doesn't sound a lot but let me tell you that if the central column * gives in a res filled with that pressure, it blows the top off with quite a bang!
* that you've wisely replaced with threaded acrylic tube not quite sized correctly or threaded to the correct size
