- 19 May 2011
SSD if you have the space . 3???. 4
Why? Why would this cause any issues whatsoever?
I imagine certain games lend themselves more to raw disk performance than others.
I should uninstall the games I don't play much but I just keep adding more drives, I'm up to 3 totaling 1tb.Yeah me too, i havent had an HDD since 2013 but i only use the PC for games and i have a fast fibre connection so i dont need much space as i just download games when i wanna play them, if ya have a poor connection then i guess ya would wanna keep all your games handy and if your steam library is anything like mine then that would be a little expensive on SSD![]()
Why would I do that
C: (OS) 64GB SSD
D: (Games) 1TB Western Digital Black
I can wipe the SSD, if I get BSOD which kills the OS, or a virus, or if change from one Windows version to another, and the games are still there.
No it doesn't.
Please provide evidence.
"All my game installs are on the same 1TB SSD drive as the OS as it by far provides the best performance"
No it doesn't.
It is a VERY easy job to back up your steam folder and other files before wiping the OS. I no longer have any non-Steam games so it's very convenient.No need. Anyone with knowledge in computer hardware knows why it's slower.
Also you're saying wiping windows drive is better with all your games and savegames, then having it split up into two? LOL
Who is saying about mechanical drives?
Two drives will be faster than just the one.
That doesn't answer the question.No need. Anyone with knowledge in computer hardware knows why it's slower.
No I didn't.Also you're saying wiping windows drive is better with all your games and savegames, then having it split up into two? LOL
I didn't know you were talking about two separate SSD's. I was talking, as were most others above, about having an SSD OS drive and a mechanical drive for storage/games. My only point was that the OS SSD will be faster than the mechanical games drive for game installs.well if you have two SSD's, one for OS, another for games, then the two SSD's will be faster. Plus the same thing, can wipe OS leaving games untouched.
Not that I would buy SSD for games as not enough storage.
"It is a VERY easy job to back up your steam folder and other files before wiping the OS"
I don't need to do that. So why bother LOL
Why would I do that
C: (OS) 64GB SSD
Amateurs lol
I hope you're just trolling. But your OS takes up some of the cache on the drive, as does your game, with your game being on it's independent drive, it has more read/write cache to play with? It's computing basics 101. One thing this thread has highlighted is the lack of basic knowledge of how a computer works to all these 'PC gamers'. I guess buying pre built is an entry these days sure, but people really need to learn the fundamentals.
That is a hilariously arrogantly worded post.
