Caporegime
- 18 Oct 2002
The fastest for a 6950x (10c/20t) is 5.7ghz so im sure a 6900k could go faster.
Edit: The 5960x managed 6.45ghz![]()
http://wccftech.com/intel-core-i76950x-overclocked-whopping-57ghz-details/#ixzz4AFloY7C1
The first runs they did were at 5.2Ghz, they then went on, it doesn't say what was benched or what was done. Again what you can overclock to and run either just cpu-z or harder things like superpi on a single core with all others disabled is entirely different to what you can do with all cores fully loaded in a longer and much tougher benchmark, the speeds are night and day. You might be able to get 7.5Ghz single core 7700k, but all cores full loaded.
Broadwell-e overclocked quite a bit worse than Ivy-e on ln2.
