Poll: SO RYZEN: WHICH ONE DID YOU BUY OR ARE GONNA BUY?
Which Ryzen did you buy or are planning to buy?
  • 1700
    Votes: 142 41.0%
  • 1700X
    Votes: 92 26.6%
  • 1800X
    Votes: 112 32.4%
  • Total voters
    346
Went for the 1800X. Always wanted a high end CPU and this is my way in for a price i can afford. Waiting for more mATX boards. Hopefully a ROG Gene variant at some point and then stick 16gb of 3200MHz RAM in there. Then build a pc for my nephew with the parts i upgraded...
I'm itching to pull the trigger on the 1700X, but I've got no idea which AIO cooler i should be looking at, and if any of them will fit AM4 out the box?
I want to buy, seems a bit crazy (without more data) choosing between the offerings. DDR4 seems really pricey atm (SSD is covered) so my hand may well be forced downwards on the CPU to a 1700, especially as cooling is included. Without more detail of what the 1700X and 1800X brings to the party "real world" I'll probably sit out the first wave.
It might be a smart play to get the DDR4 earlier? Advice on best value ryzen friendly/tested ram would be great. I had my heart set on 2x16gb as a minimum, £300 seems so high though...
TeamGroup Night Hawk 3000MHz 32GB Kits are really nice and £210 :)
none at those prices.. isn't the idea to compete with intel?
Surely you're joking?
These are the 8-cores, and the prices are amazing.
I'm going for an 8-core for editing work, but also can't wait to see the prices of the 4's and 6's. I'm sure those on lower budgets will be very happy.
I will wait for the more mid range cpus then something that compares to i5 etc..
There will be plenty by the looks of it. A couple of 6c/12t looking to be priced around Intels i5 4c/4t and a fair few AMD 4c/8t chips priced lower than that
Then there are the AMD 4c/4t priced around intel i3's and higher
Thats the one, great stuff, we do white and blue ones too. Also 16GB kits too! :)
3000MHz is the sweet spot for sure!
im a bit confused, on the info for the asus prime 370x it says max 2666mhz ram and i thought 3200mhz could be used on all the ryzen motherboards
I'm waiting for reviews to see exactly what the differences are between the 1700 and the x chips. If you can just straight up manually overclock the 1700 to the same speeds that you can get out of an 1800x then its a no brainer. If they x chips clock better then they might be worth the extra price.
me too..
