Permabanned
Zeed Joins the Hype train
With quad channel not being supported, I'm taking it people are opting for 2*8GB or 2*16gb kits?
Not sure you read it right. It says in regards to that mobo that the way to get more life out of the AM3 cooler... is to switch it out for an AM4 cooler
I know the tdp doesn't matter to cpus but it does with gpus as it wont exceed it is ryzen like that there must be a reason the 1700 is so much cheaper.I think the x stands for xfr which is where the cpu overlclocks automatically.
You should be able to overclock manually.
Anyone skeptical about the PCI-E lanes for SLI ?
What's the logic behind it? I'm waiting till more motherboards are out till I buy but I do prefer Asus most.
I'm either going for 2x16Gb or 4x8GB. I need to know which will be better for tuning/overclocking.
I think the only difference is the 1700 has a lower clock speed.
It seems they all have XFR, even the 1700 so it's not entirely clear what the "X" denotes.I think the x stands for xfr which is where the cpu overlclocks automatically.
FYI
5.2Ghz, still the same F1 stepping on (F4 were the latest sample ones).
Same I thoughts it would be like intel's k prefix but still says it supports itIt seems they all have XFR, even the 1700 so it's not entirely clear what the "X" denotes.
But should all clock the same. I'm hoping as they are all technically the same chip just different clock speeds a week to wait now
Another screenshot showed two programs displaying completely different voltage values for Ryzen, so we don't know yet whether that is accurate.Damn at 1.875v is that on ln2 ?
