- 6 Sep 2016
But it's costing you £100. Where your system is fine already. Not like you have 4GB RAM, dual core CPU.
I know but if I'm, brutally honest with myself I just want an Asus motherboard, would it be better moving to something like LGA1151 to get a cheaper CPU/Motherboard or do I just need to settle that the X99-M WS is my only option?But it's costing you £100. Where your system is fine already. Not like you have 4GB RAM, dual core CPU.
I want the fan control though, I had an Asus motherboard before and the fan control was great, I guess I don't "need" it but it would be nice to have something that just worksYou don't need a new mobo though...
But it's noisyYou're wasting your money. Keep what you have till it's rubbish and slow
Any good recommendations?Get a fan controller
But it's noisy
What about automatic ones/programmable ones, what are your thoughts on the Grid+?Any that lowers the fan speeds![]()
Yes but what controller is the question? Overall goal is to minimise noise (Heck I don't even mind a new air cooler)Buy better fans, buy a fan controller?
Gentle Typhoons. ....
I say do it, but tbh if you want smaller then itx is the next step and there aren't any AM4 itx mobos at launch.
Looks like I might have to "downgrade" to Z270 for ITX thenThere's not even any good mATX ones at launch, the ones with VRM heatsinks look a bit half hearted and most have none at all
Hope asus makes a rog mATX for am4
Can't recall how long ago they were discontinued.
With some compromises I'm sure you could still get some.
Didn't like them personally, fitted out my case, didn't like the high tone of the fans and sold the lot again.
