FT is one to ask about Pro4's as well as I believe Mitchelin sponsor him.
1200 miles is nothing for most tyres, barely broken in!
Extra advice which I always struggle to follow - set everything bike related up at least a day before (not the night before or last minute the morning before). Do a short local couple of mile 'test' ride, low intensity but it'll be enough to iron out any niggles like gear problems, mudguards rubbing, or a flat tyre on the start line (been there & got the tshirts!)
Nikwax Tech Wash is recommended for washing 'waterproof' layers (cheapest place is Tesco), it revitalised my Norain/Nanoflex arm & leg warmers, but I've not tried it on other things (yet). There is a TX.Direct which is intended to wash into non-waterproof fabrics to make them waterproof, I may try it out at some point and wash a pair of padless winter tights to see if it's a cheaper alternative than buying Castelli/Sportful/DHB 'norain' type tights. Will wash my overshoes in either/both as well, forgot to throw them in last time!
I ride long sportives pretty much the same, usually try to find some others to chat to and some easy wheels to follow and work with, trying to 'lose' the first couple of hours without burning too many matches. I actually prefer a few climbs early so I'm off infront of those who hammer the start/flats but then can't ride any elevation (as find they're rubbish wheels to follow/unsuitable & unsafe to ride with).I've only got two to go on but this inevitable leads to everyone bunching up for the first few miles as people drop their water bottle/have a puncture/snap their chain/derailleur falls off (delete as applicable) but after a few miles it will thin out and you can do your own thing. TBH I don't even mind the slow start as I try and keep the pace way down for the first hour anyway.
I have a selection of Sportful NoRain things (jackets, jerseys, warmers & shorts), all are good for showers and 2-3 hours riding but any heavy rain and wetter roads there's only so much they can do (as they're just coated fabrics, like Castelli Nanoflex).Any suggestions for reasonable waterproofs for my legs? On my long ride in May I'll be wearing bib shorts all the way, but given British weather wouldn't mind something breathable, light, thin, waterproof, and of course cheap, to go over the top just in case. Given the long distances involved I really don't want boil in the bag, and I guess I might just have to contend with getting wet. Really keen to avoid kit being wet when getting back into it though.
- Wet club rides I generally wear layers which will dry out easily, occasionally with my 'packable' rain cape (which is quite breathable). This time of year I find my windproof softshells with a windproof gilet is usually enough, heavier rain I tend to not ride in...
- For commuting in heavy rain I have a DHB EQ2.5 jacket, it's pretty breathable (being 2.5 layer) and very waterproof. It's a bit of a bad fit on me (now) so it only gets used occasionally in spring/autumn. I have got a pair of DHB mono waterproof overtrousers, they work well but are non-breathable. The fit isn't great (I wear a set of snowboarding bracers holding them up as had to buy Large to fit my thighs), but they're loads better/closer/adjustable fit than your standard 'outdoor' waterproof over-trousers. For audax type rides (low intensity) they'd be ok, but only for heavy cool rain.
