So what's wrong with foaming it and then taking a cleaning glove to it for an extra wipe, removing the need for additional cleaner and bucket?
Interesting
Traffic film remover would do the same job and cost less and its less messy.
but where's the fun in that![]()
Would also eat any protection you had on it.
That sounds like tar or iron so a product like IronX or a claybar depending on which of these you think it is.What is good for getting stuck on black bits off of alloy wheels? I've done a foam, rinse, Sonax wheel cleaner, rinse, 2 bucket clean (brushes and mitt), rinse and still some remain![]()
I find the bilt hamber wheel cleaner great! much better than the sonax one which did the job but never got my wheels 100% clean. It probably iron or brake dust that it struggles to remove.What is good for getting stuck on black bits off of alloy wheels? I've done a foam, rinse, Sonax wheel cleaner, rinse, 2 bucket clean (brushes and mitt), rinse and still some remain![]()
I'm surprised at how much dirt is left there, there can't be any treatment on that car surely?
The purpose of the foam is to moisten the whole surface of the car, keeping the surface dirt soaking so that when you rinse it off the dirt is thoroughly loosened and comes away from the paint. It's the same principle as soaking dirty pans in the sink before you wash them. The snow foam isn't really meant to drip off taking the dirt with it. It's the subsequent high pressure rinse that does that.I've thought about this, is it beneficial to have foam so thick that it doesn't run off the car? I only ask as surely if the foam is slowly slipping off then it's taking the dirt with it?
Is there any secrets to waxing/polishing a white car ?
As I seem to use half a tub of wax due to not being able to see the wax when applying it..![]()
