Caporegime
- 9 Nov 2009
- Planet Earth
They haven't, a guy posted it for fun on another web and wccftech copy and pasted.
Yet,you made sure you actually ignored what he said and what loads of people translated here from the review. Its not a Ryzen 7 1700X - its an ES and it does not even have any markings on it like review samples or ones you can buy. The picture is there in the review.
The chap said both the CPU and the board were ES,and the board BIOS was buggy and it would not run the RAM above 2133MHZ. Its there in the review. It does not boost above 3.5GHZ which again is in the review.
So that is a 3.5GHZ 8C CPU against Core i7 6700K running at up to 4.2GHZ and a Core i7 4770K running at upto 3.9GHZ and the former has 3200MHZ DDR4.
You even looked at the power consumption its LOWER than a Core i7 6700K which indicates its probably not boosting that high.
BUT,BUT AMD IS DOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOMED!!
