if i get the 1700, do i have to change a bunch of settings from stock just to get it to run stable? im not talking overclocking, just to get it to perform well and stable, is it gimped out of the box?
No.
would u recommend it over the 7700k?
For what purposes?would u recommend it over the 7700k?
fast day to day pc, infrequent gamingFor what purposes?
This is a rehash of my other post pretty much but sums up the current situation of Ryzen
1) Many reviews were done on non fresh installs of Win, infact some where straight hardware swaps.
2) Many reviews were not done on updated bios
3) Many reviews were not done with High Performance mode, HEPT disabled or SMT disabled
4) Many reviews were done on the Asus Motherboard, which it now seems is exceptionally flakey
5) Ryzen has Bios fixes and Windows patches to come to fix issues, including Thread priority, SMT Scaling, Memory stability
6) There are numerous Ryzen videos if you bother to look that show it competing with 7700k in real world scenarios, this is what matters, not artificially gimped scenarios that are never going to happen for the majority of users.
7) All of Intels CPU releases were flawless
8) Many games are coded towards Intel hardware, its a fact, due to the state of the market and AMDs inability to perform
I lied about one of those above points.
Personally i would not waste money on a 1800x or a 1700x these are leakier parts and as such run a lot hotter and are above the efficiency and optimal curve for these processors, the sweet spot seems to be the 1700 with around 3.9 - 4ghz clocked manually, with currently SMT disabled and a few windows tweaks.
Ironically with it setup correctly its within touching distance of the 7700k in many many games, once they fix the SMT issue and get some other stability and performance fixes in, i can see this chip being even better, infact i see it as the go to chip.
Looks like Gibbo was spot on. If you're going to manually overclock get the 1700, all the performance for 60% of the price.
Too any excuses there I'm afraid. For one I'm sure CPU reviews on new intel hardware is done in a similar way, ie, the pre-installed bios only, not a reinstall of Windows. If games are coded towards Intel hardware (and I doubt it),that's the way it is - they should develop CPU's to take the Intel instructions and not do something different and use the fact nobody has implemented it as an excuse for lower performance. Shouldn't have to tweak the setting you mentioned either. I'm not jumping on the negative bandwagon just pointing out a few things - too many excuses here.
Seems to be a bit of a rush job despite being in development for however many years.......one of the issues I have with AMD stuff is the problems early adopters face.
If MS wont have drivers out for Rzyen for a month is it still worth reinstalling windows straight away ?
Reinstall Windows definitely, also do the performance tweaks that have been mentioned, disable SMT etc until its fixed.
thanks just deciding how much custom radiator volume i should slap in my machine...if i ever get a mobo that is lol
each is better at different things, so we have choices to make. Which I think is pretty positive, hopefully it lasts a long time and we won't simply be making our CPU choice based solely on budget
Which chip you getting? in all honesty these Zen chips wont clock very high, its an architectural limitation it seems. I imagine future iterations will be better clockers potentially. Im looking at just using a 280mm AIO For mine at 3.9 / 4ghz once i get it.
The 1800x Im only looking for 4Ghz over all cores... Problem is i am a bit OCD when it comes to temps![]()
as 8Pack has said, they are designed for high cooling, if your going custom water loop you may find it reasonable, but i can also imagine, if your worried about temps, you probably wont be impressed by the temps of that CPU.It's roughly comparable to a good 240 AIO. But quieter at idle.What about the Noctua NH-D15?
