Your OVERCLOCKERS order will be delivered today between 18:53-19:53
This is torture!
I would have paid the extra to get in delivered earlier im sure there was an option to upgrade delivery while in transit ?
This is torture!
Sure, why not? I'm running a 3.5 year old mobo now and if I could get a better CPU to slot into my current mobo I'd stay with this mobo for a few more years yet. But I can't, because Intel change sockets with the wind.
Thing is even if AMD do keep to the same socket for the next four years would you really want to pair a cpu with a 4 year old mobo? Surely there might be draw backs and features you might be missing out on if going this route and you would want a newer board to match a future cpu.
Fair enough I am the opposite. I wanted nvme, which my last board didn't support properly z87 plus I wanted to run faster ram.
The guy has stated that he patched his Asus CH6 Hero with the last BIOS, which includes the last microcode (CPU firmware upgrade) by AMD.
And the performance boost was big, compared to the initial review he did, even if still using the same 2133 memory. That microcode resolved an issue between the CPU and the IMC.
In addition, running Windows on balanced mode prevents Ryzen from switching clockspeeds and voltages any faster than 30ms.
If the windows are set on High performance, it allows it do go into 1ms, full speed, switching. Imagine how faster the CPU->GPU communication is when the entire CPU is allowed to be 30 TIMES more responsive with boosting?
Which shows, all issues are software related.
Clock for Clock: Ryzen, Broadwell-E, Kaby Lake
https://www.pcper.com/reviews/Proce...d-Zen/Clock-Clock-Ryzen-Broadwell-E-Kaby-Lake
I can't see any mention of memory speed. Pinch of salt test.
I don't understand the scrutiny.
That review was positive![]()
That's just pulled out of absolute thin air.
There's absolutely no guarantees.
Because if it doesn't beat a 7700k in gaming then it's a failure of a cpu![]()
With AM4 you could have just upgraded the board. Though Z87 can support NVMe. But why just force someone to upgrade a motherboard, when you can also force them to buy a new CPU too. It's a con.
That is startling.Ryzen's minimum - the inner bar - are fantastic.
Just did the same after reading various problems on another forum re the heroSo who's using the GA-AX370-Gaming K7? That's what. Have switched my back order crosshair for.
That's superb!That is startling.
