Poll: SO RYZEN: WHICH ONE DID YOU BUY OR ARE GONNA BUY?
Which Ryzen did you buy or are planning to buy?
  • 1700
    Votes: 142 41.0%
  • 1700X
    Votes: 92 26.6%
  • 1800X
    Votes: 112 32.4%
  • Total voters
    346
21 Oct 2012
I've just moved house so have had to postpone my rebuild.
Currently running a 3570k clocked at 4.2. I'm considering the 1700 if they can get these initial launch issues resolved. That said, if the 1600X and 1500X launch in summer and are well received then either of these could offer the best bang for the buck.
19 May 2010
I had a pre order for the R1800X which I cancelled, I cannot be bothered now to have to wait for mb vendors etc to release new bios so things can work correctly out the box. I will give it 3 months or so and will most likely get a R1700X.
17 Oct 2002
Lots of folks going for the Crosshair it seems, despite issues. I must be one of the few going for the Gigabyte Gaming K7!
I've always been more of a gigabyte fan than Asus and it is the giga I am aiming at currently. Bad experiences in the past with Asus have tainted me, although I have had no recent experience.
13 Nov 2002
Scotland
My 1700 with Gaming 3 arrived yesterday, all good so far.
Lan on the board didn't work correctly on the base drivers but seems fine after an update from Gigabytes own set. Also, when first starting the screen was blank through the post screen etc for the first few time for some reason but works fine now... thankfully.
10 Jan 2014
I have currently gigabyte and now I was thinking of going with asus but those issues put me off a little:/ especially if you want to watercool just to find out bios crashed and you have to take the board out. Wish there was more reviews of MSI. Apparently their latest bios increased performance by quite a lot (not sure because it was poor in the first place and now caught up or because it's better than others now)
HeX
HeX
20 Jun 2004
Huddersfield, UK
I plan on going with the MSI X370 Carbon when some appear in stock. Just put my 1700 order in, was originally going with the 1700X, then changed my mind to wait for the 1600X, now changed again to sod it and just get a 1700 and aim for 4GHz all core OC. :D
2 Mar 2017
blackpool
ok put an order in for a 1700 and asrock taichi .. mem gone with Kingston 3333.. wanted gskill but could be arsed ordering parts from all over plus a few other bits new tubing, block ..
my old build is a 8350 so old. but shes done me fine 5ghz from day 3 ..must be 6+ yrs old
Man of Honour
13 Nov 2009
Northampton
B350 Gaming 3? I noticed the first boot it took quite a while to post and skipped the splash screen. It seems to post quicker to me since I flashed the F4 bios.
LAN worked out of the box on my old windows install though
13 Nov 2002
Scotland
Yeah, Gaming B350 Gaming 3. Glad I'm not the only one who noticed that issue :)
I'll need to check what bios version I have though, I thought it only had one version so far (release version)
All good now though
13 Nov 2002
Scotland
I can only see version F1 on the driver download page... I'll try a different browser :)
Edit, just checked and it came with version F3
17 Oct 2002
How is the Gaming 3, I'm not normally one to spend mega bucks on a mobo and I am seriously not bothered about RGB.
