Couple of questions for those lucky enough to have had their delivery
a) Is the platform stable other than having a few ram issues at the minute? AMD haven't always been the best when it has come to drivers.
b) Does the cpu underclock itself when idle as intel chips do when you have an overclock set? I know overclocking disables xfr but I was wondering if it affected the down clocking too.
22:40 actually![]()
Mines been as solid as a rock since 11am Saturday morning with a mild 3.6ghz overclock on a 1700. It's done a bit of gaming, some synthetic benching, a bit of encoding and plenty of general use since then and I've not had a single hiccup.
Not sure on it down clocking at idle as I've not really paid attention
I think he means re 2nd question Like Intel's speed step lowering volts/core speed looking at the cpuz results it looks like it does and from what i have been reading thus far the Ryzen is far more efficient at this than Intel...
3200mhz memory is expensive![]()
5803 has been posted by one of their Devs unofficially if that interests you. I've been running it fine.Can someone please link me to the best/latest BIOS for Asus CH6? I have to board arriving today.
I can see 5704 on the site. But wondered if there was a Beta anywhere?
Edit: oh, that is Beta. Nevermind!
Same as mine, it has been solid once I did a fresh Windows install.Mines been as solid as a rock since 11am Saturday morning with a mild 3.6ghz overclock on a 1700. It's done a bit of gaming, some synthetic benching, a bit of encoding and plenty of general use since then and I've not had a single hiccup.
I have noticed that during idle it clocks down to around 2.2Ghz. I managed to clock my RAM up to 3000Mhz too using Gigabytes AutoTune application which worked really easily, just need to clock the CPU up now.
Cinebench results currently coming out at just below 1500 (R7 1700X with Gigabyte AB350 Gaming-3)
What settings have you used for 3000mhz on the memory? I've had no luck so far getting above 2666
Using what RAM? Is it single or dual rank?
TeamGroup Dark 3000mhz, no idea if it's single or dual rank
Edit its 2x4gb kit
Gigabyte B350 Gaming 3, so I know I'm pushing my luck trying to get any sort of decent memory speeds at the momentThe 16GB kit (2x8GB) uses 2 ranks unfortunately. I'll see if i can find the 2x4GB kit, but would assume single given the density.
What motherboard are you using?
Will check when I am home.What settings have you used for 3000mhz on the memory? I've had no luck so far getting above 2666
