Aye, I'd kill my productivity if I moved to the 7700K, and that smidgen of an increase in FPS won't help me then.Yeah, afterall it is the x99 series that these r7's are aimed at. Not z170/z270
Very helpful information thanks. Can I find any of this info on the AMD website and is it official figures?1.45v top voltage 24-7 as advised by amd. Temps top is 95 but for me 80-85 is enough.
That is why you are having these results. Although you are overclocking it is after windows has loaded not prior set in bios. Without seeing how this tool is working it maybe a better way to improve power though I would ordinarily never use such a tool. I have always set in bios as per normal overclocking. Normally hate installing manufactures software that does this sort of overclocking, but if it actually does help power i might have a look see.
Would you mind posting your o/c settings mate?This has been clocked in the bios mate.
Matt, did you got your gear yet?Clocking via the Ryzen Master Tool should allow you to apply a OC for gaming then reset to stock for idle/browsing situations where you want the processor to downclock and use less power.
Have you seen how the performance scales from the 1060 to the 1080 on 1080p? It's a sub 10fps difference.Ghost Recon Wildlands
1080p with GTX 1080 1060/RX480
7700K 5Ghz vs 1700 3.9Ghz
This game is not at all optimized for the ryzen or 7700KHave you seen how the performance scales from the 1060 to the 1080 on 1080p? It's a sub 10fps difference.
So far i have a R7 1700, Ryzen TShirt and Memory. Can't find a X370 Motherboard anywhere in the Uk at the moment.
I've been without a desktop PC since Sunday. Currently living off a Carrizo laptop connected to my 4K display via HDMI @ 30Hz. You don't know how lucky you are all to have desktop PCs and 60HZ+ displays.![]()
Yes use Windows 7Where is there anything official from MS regarding the windows scheduler and updates?
Thats why I didn't dismantle my PC yet to put it for sale, two weekends had second thoughts just in case.....
Not going to suicide![]()
Yes use Windows 7roflmao
If you see a surge in the Windows 7 usage, it will be MS fault.......
Hell, Linux these days looks much better imho
Ryzen is a dream come true for Linux..... Linux is concord mode on ryzen.Yes use Windows 7roflmao
