- 5 Sep 2011
- Surrey
Board manufacturers didn't anticipate this kind of hype and demand![]()
Nothing to do with it.
Now the waiting game to see if my return is accepted. Then get another board!
on a normal boot the tomahawk gives CPU and ram lights together at first for about 20 seconds then the GPU light will come on then boot up. Having no second light I would say is a ram issue. What are you using?Now the waiting game to see if my return is accepted. Then get another board!
I have no experience with those but gibbo recommends them so they must be decent.
Do you have no access to other memory?
Well with the way Premiere Pro is made that 6950X isn't really needed anyway!
FCPX also uses all the resources you can chuck at it! My 2013 Mac Pro was a damn powerhouse.
If Apple didn't abandon the pro market I'd still be on one of those; or you know allow people to upgrade the GPUs at least.
Since then they've focussed squarely on their consumer line that uses mobile parts; so they could get QuickSync in there all the time as well, to further help.
FCPX gobbled up all the CPU and GPU performance.
Asrock Taichi supports ECC, and it works in Linux.
TL;DW:
- Basic board overview.
- [AM4 is a ] Great platform for Linux. If you are building a PC today specifically for Linux and workstation, its hard to suggest anything else.
- Support ECC memory.
- IOMMU grouping not the greatest, wait for patches.
- Showed a quick GTA5 benchmark teaser. (!!!)
- 1800X OC'ed to 4.2GHz, all cores(check description for validation links).
- His 1800X-OC Beats 7700K(4.5GHz, stock boost) in CPUZ & but not in Cinebench at single-threaded tests.
- Got RAM speeds to 3200MHz(GSkill Trident Z) stable on the latest BIOS.
- Allows overclocking through PStates instead of OC'ing via multipliers and voltage. (Possibly an AsRock only feature?)
- More overview of the UEFI.
- More GTA5 in-game benchmarks. No comparison, but FPS at a rock-solid 130-140+, dipping to 90-100 only a few times.
- New platform, new software therefore rough around the edges. Should be normal eventually.
- Great platform for parallel computing and workloads which require 8 cores.
- For single core workloads or apps which aren't heavily multi-threaded, it will not beat a 5GHz Quad Core(7700K).
Thanks for that - been looking at some motherboards,do the cheaper ASRock ones support ECC RAM??
AMD Ryzen series CPUs support DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC & non-ECC, un-buffered memory*
Based on the Specs page on the ASRock website for the ASRock AB350M Pro4 I was looking at before, yes.
Look at the asterisk? Most of them say they support it, but not in ECC mode.
http://www.asrock.com/mb/AMD/AB350M Pro4/index.asp#Specification
Well the Taichi does so far. Gigabyte recently added it to their supported RAM as well.
the asterisk in this case just says "*Please refer to Memory Support List on ASRock's website for more information." doesn't say that it won't run in ECC (unlike some of the other vendors that specifically say that)
