Mate aren't both screenies the same?
My testing so far.
I don't use Prime95, as when I got the i5 4690K I noted on ROG forum that Raja@Asus (Asus techie) stated it can pull so much power through CPU = degradation. I set my CPU 4.9GHz @ 1.255V CACHE 4.4GHz @ 1.10V, ~1yr+ ago. I used 48 loops of x264 (~8hrs), first as that only loads CPU and was highlighted as a cool running AVX stress test (I'm on air). Next 4hrs RealBench Stress mode and must have done several hundred hours of f@h plus gaming in past year or so. No issues to report, from my method and my uses of PC, it is not uncommon for me to do 48hrs+ continuous f@h runs.
So on the Ryzen 7 1700 I'm using similar method. Just like when binning the 2x i5 4690K I looked out for what made my rig hiccup quicker when OC'ing, as if I sorted that then others fell into place. I went for RB first on 3.7GHz profile, but noted x264 was making CPU fall over quicker and requiring more VCORE, so for 3.8GHz I went for x264 first.
CPU: R7 1700
Mobo: C6H (FW 0902)
RAM: 2x4GB Corsair LPX 2400MHz C14 (was supposed be using G.Skill 2x16GB 3200MHz C14 but turned out faulty, waiting on RMA)
HSF: TR Archon SB-E X2 with TY-143
1st 2hrs RB Stress mode @ 3.7GHz ACB @ 1.18750V in UEFI (DMM 1.19V)
2nd 10 loops x264 (~1hr) @ 3.7GHz ACB @ 1.20625V in UEFI
Next I did a tweak to UEFI as some owners of C6H had on OCN stated to Ellmor (Asus MB R&D) that temps differed between ROMs.
Quote
extract link.
3rd 10 loops x264 (~1hr) @ 3.8GHz ACB @ 1.29375V in UEFI
4th 2hrs RB Stress mode @ 3.8GHz ACB @ 1.29375V in UEFI
Now the weird readings in HWiNFO are down to SMU (On die controller) requiring an update via UEFI, source of information is Martin Malik, author of HWiNFO,
link to post.
I have also created a thread on OCN where in OP I place
Rysen Essential info (when I get the time
