Caporegime
- 18 Sep 2009
- Dormanstown.
If this line up is true it's going to stir things up a lot:
They look solid.
That 1400 though overclocked to 4GHz is going to wipe the floor with the i3.
And the non-K i5 (which costs more).
The R5 1600 is looking like a beast. It should clock to the same as my Westmere-EP part, has the same number of cores and threads, yet will have far better IPC (including newer instruction sets) and much lower power consumption. All for the same price as an i7-920 back in 2009 (~£220).
4c/8t with more IPC than BW-E
Agreed, was talking more personally though. Once you go hexcore, you never go back.The R5 1400 is going to be the part to look at - one of those with a RX480 or GTX1060 is going to make a solid gaming rig.
No it isn't - if that is the case,a higher R7 1800X in gaming would would be faster than a Core i7 6900K especially with a higher clockspeed,except it isn't especially if you look at mixture of lightly threaded and threaded games. Please don't overhype it,otherwise it will be like the RX480 and people thinking at launch it would be a Fury X.
6 Cores for £200? I've found my biting point.
Don't under-hype it?
As far as I've seen Zen is higher IPC than BW-E, other than in games. Many reviewers have even written exactly that in their reviews.
And the gaming situation is still in limbo. The current opinion is that games have been optimised for Intel over the years, and Zen is different enough to need patches to be used to its full potential
Imagine if we were still 1.50 to a dollar.
Wouldn't that benefit Intel just as much though?Imagine if we were still 1.50 to a dollar.
What did you expect? Core i3s are clocked lower than Core i5s, which are clocked lower than Core i7s.what's going on ? why is the 8 cores clock higher than a 4 core ? i dont get it, even the 6 cores is set to 4Ghz, why is the 4 cores 3.7Ghz ?
Not really? The AMD price point is already better, it'd just make AMDS 6 core under 200 pound.Wouldn't that benefit Intel just as much though?
It was actually rhetorical. If you decrease AMD and Intel prices by the exact same amount then it doesn't benefit either of them (just the consumer).Not really?
