What are you testing with? I've just had 3.82 @ 1.34v passed realbench for 2 hours then failed in overwatch just loading menus lol.
Both are very capable boards.8pack in your opinion is the crosshair worth the extra £30 or so over the taichi?
If it was your money?Both are very capable boards.
Has anyone done a reinstall of windows 7 on the crosshair? I'm trying to do one at the moment but when I get to the language page it doesn't recognise my keyboard or mouse I have them plugged into the usb2 ports but nothing. Anyone got any ideas?
I have no idea how do do thatyou need a ps2 KB and mouse to do that and the crosshair does not have that port, to use USB vertions you have to inject the dirver into the iso on a usb pen drive
Can't find it in the crosshair biosNo you don't.
OP - go into the bios and enable USB legacy mode.
Yep found it and it was activeBoot menu > USB options?
Question:
Is there a guide to overclocking Ryzen?
So far I have set a manual voltage of 1.275V, and a manual clockspeed of 3.7GHz which is fine, however the clocks are locked to 3.7 in Windows so it idles hot
Is it better to use Vcc offset?
If you are on an Asus board offset won't help. Once you set a target other than auto, it disables stepping down.
Though I think the crosshair may allow it.
Not sure about other brands
Question:
There is a way of stepping down using custom P states on the CH6 AMDmatt posted about it in the Ryzen owners thread.
https://forums.overclockers.co.uk/t...-owners-thread.18771445/page-27#post-30598580
Not tried it myself yet but as soon as i get time I'll be all over it!
