- 14 Oct 2007
- newcastle
Anyone got any advice for getting my new 3200 ripjaws above 2666? I Get an 8 error code error code if I try to go above that
is your rad getting hot too cause if not i think your pump is bust broAlso can changing ram change the load temp? Yesterday I was at 3.9 stable no more than 62c since I have put the new ram in it now shooting up to 70c then crashing, I have reseated the the AIO twice so I don't think I have knocked anything, it is definitely getting hot because I can feel the heat in the tube
Oh, that's a shame! I only bought the ASUS because it had the fewest RGB lights ...
I didn't even notice there were RGB lights on the Prime!Lol. One of the things attracting me to the Gigabyte K7 is you can fully control the RGB's, including off![]()
Ok I'm officially confused.
Had my CH6 arrive today, also got my Corsair Vengeance LPX 16GB 3200 arrive.
Spent over an hour tonight trying in vain to get the machine to POST on anything more than 2666mhz.
I've got the sticks in A2+B2, but setting the profile in the BIOS to 3200 or even 2900 results in no POST, tried setting voltage as high as 1.5v too but no dice.
Any clues or hints please?
I'm having the same problem with my gSkillsOk I'm officially confused.
Does anyone have Premiere CC here they could help me test an issue?
I can't export video above 3.3ghz on my 1700. I think (hope) it might be related to this FMA3 issue http://forum.hwbot.org/showthread.php?t=167605.
My system is stable for all other applications 3.4ghz - 4ghz.
I've done a sample Premiere project below that just has a sample video and a couple of demanding effects. If you can try to File > Export > Media to the default H264 settings and see if it processes OK on your overclock.
https://mega.nz/#!XYNzyR6B!3-ibb1Vaapsm2ZPSUZsfAO9-Ixnycfe97_eB3sTOFl4
If I know it is a common issue I can stop digging.
Will try downloading trial tonight and see
Says project file is corrupt for me premier CS 6Does anyone have Premiere CC here they could help me test an issue?
I had a quick go last night using the settings that AMDmatt posted here
https://forums.overclockers.co.uk/t...-owners-thread.18771445/page-27#post-30598580
And it booted fine with my ram at 3000. I just lowered the cpu clock a little due to being on the stock cooler
You can't load cc projects into cs6Says project file is corrupt for me premier CS 6
Has anyone done a reinstall of windows 7 on the crosshair? I'm trying to do one at the moment but when I get to the language page it doesn't recognise my keyboard or mouse I have them plugged into the usb2 ports but nothing. Anyone got any ideas?
