Ryzen CPU's perform better with faster memory but There are currently problems with some motherboards supporting higher speed memory. If you overclock, only the x370 boards allow you to overclock the memory B350 motherboards cannot. It's better to use 2 sticks of ram rather than 4 at the moment if you are thinking of overclocking.
Is that the current status in a nutshell? If I have an AM4 motherboard that supports 3000MHz DD4 memory, is it better to buy ram that is running 3000MHz than 2400MHz? If I buy 3000MHz memory, can I buy a B350 board because I wont be overclocking the memory?
They do exist...
Ah ok, I have Team GroupGeil evo x 2x8gb 3000mhz
	Is there any way to test specific instruction sets. I hear there is a possible issue with FMA3?
Does anyone have Premiere CC they can test also?
It actually meets the top of the angled heatsink so the air hits the heatsink, runs up it, up the shroud into the jetstream of the rear case fan. It's a good design just one that isn't instantly understandable. When you think about it it's not like people have fans pointed at both sides of that VRM heatsink anyway (unless they're mad ofc).I can't believe how many mobo makers are jumping on the bandwagon of the massive MASSIVE plastic heat traps over the IO.
Nothing wrong with covering the VRM heatsinks right?
Quite interesting. Possibly going to see a good number of people switching to Linux?
Yeah but it wouldn't be as guided, I'm not saying the is a massive boost to performance or anything, just that it looks cool and despite rumors doesn't negatively affect it....which it would do without the shroud?
The top isn't covered as that would defeat the purpose.Instead the back of the heatsink and the top is physically covered which limits air movement across the top and up the back.
Well yes if you're going to be using it on a test bench with a 120mm industrial fan pointed directly at the VRM it will cause an issue but I don't think it's unreasonable to expect those niche users to remove the shroudPretty sure I've seen criticism from pro overclockers on that subject too.
Really like the look of the Gigabyte AM4s. Waiting to hear how they shape up..They do exist...
If anyone has the Gigabyte AB350 Gaming 3 and would like to test the latest beta bios, here it is. GA-AB350-Gaming 3 F6C
I did some more poking around with this. I can confirm that the Intel Linpack benchmark for Linux is full of FMA3 instructions (vfmadd...). You can check Windows executables in the same way (objdump) but I don't have Premiere to check specifically.
You could grab a Windows executable of objdump or if you must know just send me the Windows exe.
