Are the micro-usb covers covered on warranty? The rubber seal has split and the door doesn't shut properly anymore.
Don't know, Will find out when mine comes back.
Is this because of charging? Would recommend getting a magnetic charging cable, so much easier to use.
Just buy a new cover and fit it yourself. They're under £10 from Amazon or eBay.
It is yes and I have both a stand and a magnetic charging cable, but still use the port occasionally.
Might just do that, are they easy to fit?
God this phone is a piece of ****, this is now the 5th time I've had to send this phone back to Sony, 3 times the screen has come away from the phone now, this time as soon I get it back ebay it goes.
Had mine for two years. It's a great phone but the micro USB port had become faulty. My mums Z3C nav buttons have started to become unresponsive too. I think one of the updates also lowered the earphones max volume.
I switched to the iPhone 7.
I mean headphones, volume through the headphone jack. Both Z3's had a hissing sound through headphones when no sound was played. They seemed to fix that but the max volume seemed to reduce at the same time.Had the earphone issue myself, if you don't care about cosmetics pull the tin mesh off the earpiece with tweezers. Much louder afterwards
I want to reflash to the default stock software (whatever the latest version is), but it's been an age since I flashed the Concept Software and can't remember what I need to reset it. Can someone point me in the right direction please.
I love my Z3, still is fast and smooth but 16gb is to low for apps and an i7 128gb wasn't much more than an XZ 32gb sim free.
Same here, every lot of bulk app updates seems to take up more space. I'd give it 18 months tops before those updates take up the entire memory space & bricks the phone. Shame really, I think its been a good phone. Sony phones of late seem to be a bit uninteresting to me. My next choice of phone would be the same size as a Z3, but with more internal memory, SD card & be better supported as regards OS updates.
