Whats the error on the top left corner?
If you got a brand new board you have to install the bios 0902 at least. Mine didn't boot after building it. Took me one hour to figure out that I had to flash it -_-
Poor CPU
Is it working at least or got killed by the motherboard?
Anyhow, welcome to Asus spontaneous overvoltage club.[
I'm sure it's working the motherboard switched it off should be fine never switched it on again it's not worth the risk.
I have had CPUs heat up before they can take a lot of heat but it's not wise to keep using it and it will not switch on until it's cooled down anyway
