After reading some other forums, i would be careful with volts at the minute. It seems CH6 is not reading them correctly, using more than actually shown. I don't know if this is a motherboard specific issue or the the Ryzen chip itself. I'm off to get me a £10 multi meter after work to see what the true reading is.
Currently testing at 1.325v BIOS and 1.33v load (LLC lvl 4). I tend to try 3x Cinebench first as that will tell you if you are wide of the mark or not. That passed, now doing 30 mins Realbench. If that passes I'll up it to an 2 hours. I'll then start gaming on it and see how it goes. If it crashes in game, I know I need to tickle the volts up a notch.
If it passes a pass of CB and does a loop of RB i'd be VERY surprised if any gaming would be problematic.
What are you using?I bought one but for the life of me i cant seem to get it to show any readings!
It certainly sounds it. I use nothing but fluke but they're a bit expensive if you only use them for overclocking.I think it's faulty, I'll be taking it back and getting a replacement
For those posting real bench passes. Are you checking for WHEA errors? I could not get 4GHZ without WHEA errors for any voltage. I stopped at 1.45. I finally got WHEA free at 3.98ghz with memory at 3180. After 2 hours of Real Bench, I was hitting 84C as read by Ryzen Master. I am using 1.417 on voltage, with LLC on the highest setting, 140 current capability, and 120 on memory current capability. I am using the CH6 and BIOS 902. I can run 3200mhz on stock settings with no sweat.
Managed to get 4GHZ/3200 with 1.375 set (1.35 got me to Windows, but crashed with CB), completed CB OK, now to test Realbench:
My x62 is doing a MUCH better job than the stock Wraith cooler so feel happier pushing the chip today.
That worked...
Thats a good one you have there. Mine crashes as soon as I load realbench at 4.0 even at 1.44v!
