I assume a rear cam is pointless if the windows have heavy tinting?
I have heavy tinting (limo? Basically looks solid black from outside) but the rear facing cam seems fine (in daylight at least)
.What would your ideal dashcam be?
What are the nextbase cams like? I'm thinking of getting a 312GW.
If discreet and no nonsense you are after then the Blackvue is totally worth it. I cant even see my Blackvue when im driving as it is positioned behind the rear view mirror perfectly.Looking at getting one of these for the new car, is it really worth spending the extra on a Blackvue? I want something discreet and without a screen that can be tucked behind the mirror.
Yes it does , and it can omit things like speed if you likeCool thanks, and does it show things like current time, speed, location etc?
Stiff car , rough roadWhat have you done with that? Why does it bounce about? Why does it look that bad? Surely that's not the original footage (hence the time sliding in and out at the bottom?)
 YouTube compression I'm guessing it looks alright on my side
