Virtual machines is pretty much a prime candidate for Ryzen, if only for the extra cores.
Definitely, if you want to run numerous VMs I wouldn't get anything except the R7 1700 right now.Thats what i've been thinking myself surely it will run better that a 7700 and even better that a old 2600k will it now ?
Thank you for your reply
Rumor: AMD X390 and X399 chipsets diagrams leaked?
https://videocardz.com/67594/rumor-amd-x390-and-x399-chipsets-diagrams-leaked
FOR THOSE WHO HAVE NOT DISABLED HPET - DO IT NOW!
My gaming performance has rocketed.
Nothing has changed with my setup same clocks same ram the only thing I did was disable HPET.
Dirt rally at ultra
Before
Avg 112.7
Min 91.5
Max 152.4
After
Avg 145.8
Min 113
Max 196.4
Total war: warhammer ultra preset
Before
Avg 90.3
After
128.8
3Dmark firestrike (now this isn't a verified score due to the timer being disabled but even so.)
Before
3DMark Score
15869
Graphics Score
18738
Physics Score
19904
Combined Score
6471
Graphics Test 1
89.29 fps
Graphics Test 2
74.91 fps
Physics Test
63.19 fps
Combined Test
30.1 fps
After
3DMark Score
20320
Graphics Score
23813
Physics Score
25511
Combined Score
8449
Graphics Test 1
112.93 fps
Graphics Test 2
95.59 fps
Physics Test
80.99 fps
Combined Test
39.3 fps
Cinebench score did not change at all but gaming wise its definitely a difference.
Overwatch is higher too but I did not measure that, just believe me when I say my fps was around 225 for most of the time compared to 190 to what I was getting before.
*I have not tried to replicate this by re-enabling HPET but its worth a look for any gamers.
I have no clue what happened with the firestrike benchmark but the geforce overlay was reporting the exact same fps as the benchmark was. The physics scene was the most impressive for me, usually it hovers around 60 and on a 144hz screen 60 vs 80 fps is noticeable*
If anyone else wants to post their finding that would be helpful to see if HPET does cause a performance hit or its just a case of the Mrs pouring redbull into my computer when I'm not here.
Via command prompt. I rebooted and tested the above.
Before
http://www.3dmark.com/fs/12045711
After
http://www.3dmark.com/fs/12107303
The before score had faster RAM too!
What os is gavin using?
EDIT: Sounds like you have to enable/disable in both windows AND the BIOS.
Using windows 10 home.
The CH6 does not seem to have an option for it. I ran it in command prompt and rebooted. I am overclocking in pstate. The scores from before were taken when i overclocked in manual mode. Though i cant imagine this will have such a big impact.
