How is the split joycons better I was using it in the grip , think I was doing it wrong was struggling a bit when I had a go yesterdayYes, but with it you turn left and right like you're turning a steering wheel.
It's hard to make your brain work with that but if you can then it works just as well as the split joycons. When using the pro pad I still fail to turn left and right occasionally when under pressure while with the joycons it's completely natural.
