Hey man, do you want me to donate a webcam from 2010 so you can record at higher than 240p![]()
I didn't want to distract you with my physique when you should have been listening.
I'd second this - definitely use the opportunity to work with someone you know and are comfortable with to explore the option of Olympic weightlifting, or even crossfit. Crossfit itself isn't likely to lead to getting jacked as such but it may well equip you with the knowledge and environment you need to make changes. It really depends on the gym you attend as well, where I go is very barbell focuses and the "crossfit" element is mainly a short sharp finisher most of the time to get the heart rate up.Congratulations on turning it all around.
Crossfit is not great for getting jacked unless you are eating truly huge amounts of food... and even then it is dependent on a lot of things. As it stands, your heavy routine is not conducive to swolification, either, because of its frequency and intensity. We had a guy on here a while ago (who might still be lurking) who shrunk down massively and then wanted to get stacked... all whilst doing outdoor swimming. I think he had to load up with around 5000 calories a day to put on weight VERY slowly, but it worked.
Better to start off on Stronglifts (or use your OTroutine... which might not be great) and use the Crossfit gym to learn how to perform the Olympic lifts (and not do Crossfit).
My shoulder is fried, my quad is fried. Time for a 2 1/2 break (by far the longest for a year!) - I will focus on stretching and mobility whilst away. Hopefully this quad pain then goes away. Have had it before, but not this bad. At least it healed quickly last time.
Use the honeymoon to perfect lifting mobility through inventive use of... err... positioning.
Any excuse to get my kit off in a thread where tom_e is posting...
I can fit my 9yr old daughter in my old trousers
