Where did Lisa stanfield come from![]()
Was just listening some of her songs that moment I was writing it
This would be fine except they use those situations to form conclusions about gaming which is not correct.All they are trying to do is see how much grunt the CPU has when you take the GPU out of the picture as much as possible. That was the assumption anyway. Clearly, AMD's chips have bucked the trend.
Quite a boost from just a game update.
Ashes of the Singularity Gets Ryzen Performance Update | PC Perspective
https://www.pcper.com/reviews/Processors/Ashes-Singularity-Gets-Ryzen-Performance-Update
Nice. So looks like AMD's claim there are Intel-specific optimisations in most current games, and that with optimisation Ryzen will improve, is true.
Keeping the 6900K, nice.20-30% that sounds just about where performance should be, AMD need to roll out patchs on most broken games used to bench, now that ashes of the singularity is done , what's left is Rise of the tomb raider, farcry primal, and hitman.
other games are kind of OK, when you come to think of it, it's basicaly only these 4 games that gave Ryzen the reputation of a non gamers CPU.
But what about 720P on low details with 1080ti's in SLi?
https://www.pcper.com/reviews/Processors/Ashes-Singularity-Gets-Ryzen-Performance-Update![]()
I doubt it'll be as difficult as the GPU situation though, if a single game was patched for a brand new architecture within weeks.My gear tho is that the CPU landscape is going to mimic how game Devs code for Nvidia or AMD GPUs.
We'll end up in a situation where a Dev has to optimize for Intel or Ryzen.
Add the Unreal Tournament benchmark please.
We should also add in some 480p Quake 3 tests for the competitive gamers.
It's the only way to know if RyZen is going to bottleneck the Ti's when gaming in 4K in the future after all.
I mean if RyZen sucks in 480p, it surely means that with a powerful gpu it's going to bottleneck in the future, right.
Get it running before xmas and you get a free computerI have some Trident 3866Mhz on the way, if bios updates allow for it, will see how much it helps.
Well worth it IMO.So lose 10 fps on avg but gain a 50% on the minimum for 1080ti.
You're right, morning brain :/You're actually gaining 100% on the 1080Ti, compared to the 7700K.
All the minimums are better on Ryzen. It's lovely to look at really.
So if they brought such nice performance increases on AOTS, a game arguably nobody ever plays, it bodes well for AMD and the Bethesda partnership where they stated specifically they were working together to optomise the Bethesda games for Ryzen... Will be interesting to see what they can achieve.
Another consideration is the cpu makeup of Ryzen is similar to consoles is it not? and if Scorpio has a zen based core in it, with the infinity fabric and whatnot, that will also bode well going forward for console ports, as they are very well optomised generally for the console hardware to squeeze as much out of the box as possible.
Agree ....I think this has been AMD's master plan for years getting in the consoles is part of it ..this is some thing neither Intel nor Nvidia are..AMD to me seem to be the strongest moving forward for the future ...Not just being in the consoles but has a company having both cpu & gpu divisions under one roof ...
So one would hope for future games it should be an easier task for the game developers if the hardware is similar in the consoles & pc's using AMD
