- 19 May 2005
I've seen this before, solved by flashing the phone in odin yourself or taking it to a samsung store.
Nova launcher?
That's also the first evidence I've seen of anyone using the edge stuff. Might have to get around to giving it a whirl.
Standard mail client isnt the fastest at push mail neither and I have two accounts set up on it.Anyone else had issues with the Gmail app not pushing Outlook based email after Nougat update? I'm on a stock EE S7 with Nougat, before the update it was fine but now it's not pushing emails unless I physically open the app and check.
Checked that the settings haven't changed at it's still set to update every 15 minutes.
I've factory reset mine now to see if that improves things; I didn't bother before, but I normally always do. I was having quite a few issues so decided to bite the bullet and get it done. Too early to comment on battery as yet though, but the phone itself if nothing else seems a bit quicker and more responsive.
Good stuff, would be useful to know how you get on with your battery after that reset. I haven't had any issues with performance after any updates, only the battery of late.
Disappointed by the battery since the OS update. Thought it might be cache items causing it, but it looks like Nougat is killing it.
Early to say but it might be slightly better. Tonight it's not so good again but there again I've been on a train so the signal would have been up and down.
Same here, battery drain since upgrading to Nougat is horrendous.
Have you done a factory reset after upgrading to nougat? It solved the same issue (plus sdcard issues) for me.I mentioned this on here a few weeks ago, from monitoring the battery nothing stands out!
If I leave my screen on or use the phone for watching videos I can get 6 hours SOT!
If I don't use the phone, or maybe listen to music with the screen off the battery is terrible, I've seen 1 hr 30 mins SOT in a single day and that's not
even listening to music, no idea whats up
Starting to do my nut in
