Caporegime
- 8 Jul 2003
- In a house
Yep me neither, hardly looks a showcase for it.
Arkane are not going to hold off the release of their game just for a GPU release. AMD will have had to have paid them seriously big money to pull that off.Prey is the Vega starting title, it will not be released until Vega. They will come tied together.
Doesn't look good for Vega, using Prey, when its recommended specs are only a 970/290.![]()
Yep, 59 fps just isn't going to cut it.Vega is all about 4k 60fps. Good luck achieving that with you're 970.
Yep me neither, hardly looks a showcase for it.![]()
People still follow recommend specs? I ignored them along time ago
Recommend for what? 720p 30fps, 4k 200fps?
This is hardly ever talked about, I think I can count on a single hand the amount of times a dev has listed the recommended specs and what they mean.. Most of the time we just given a recommend spec with out knowing the FPS target or the Settings.Recommended specs on games are for 1080p, high settings, 60fps (or smooth game play in certain games where fps doesn't make much difference).
That's how games are designed and will be for a while as long as 99,99% market still plays on 1080p.
Of course these would be tested on a stable, fresh OS build.
I doubt the 970 will keep over 40 fps on new titles at 4k with settings turned up. Why? Grunt and 3.5gb of fast enough memory.Yep, 59 fps just isn't going to cut it.
How do you know though? Devs never state what the recommended hardware will do. Even minimum. To me minimum was to be able to run the game on lowest settings at playable framerate.Recommended specs on games are for 1080p, high settings, 60fps (or smooth game play in certain games where fps doesn't make much difference).
If they state recomended hardware for 1080p high settings 60fps then gived people more of an idea but they dont. Best off waiting for reviews.
Nothing concrete, just what a guy from Sapphire and few game devs said during live stream interviews some time ago - apparently 1080p high is how the developers see the game and design it, it's their vision of the game -hence recommended . It does make sense since this is still most popular setting.
Anything else (ultra, *insert whatever your game calls excessive AA and blur setting, 4k) is just eyecandy to give people a reason to spend more money on 500-1000 Gpus (he hasn't said this obviously, it's purely my opinion).
If I move over from Nvidia I am doing it for one reason and one reason alone. Better DX12 and Vulkan support. I feel let down by Nvidia in these areas.
Yes I have not used a 1000 series card and am basing these assumptions on my 970 but I have observed that the 1000 series have also not been great DX12 cards and with Ryzen these assumptions seem to have rising to public opinion also.
So my question to the Red team is, in the games that DX12 is an option have you been able to use it, with little to no issues?
In all DX12 enabled games with my 970, performance has regressed. In Doom with Vulkan it wasn't as good as OpenGL.
With the way you feel about AMD atm the showcase could be life like and it still would not look good![]()
Built a system for a family member forget the game but only had min spec listed and they wanted to keep the price down so we built for with the min spec the bloody thing was a slide show, it ran that was about it.
What should happen here is the dev put out a video benchmark or game play with both min and recommend spec and showcase the performance. That is how I would if Valve force Devs to post on the store page.
