It'll probably still be slower than Windows 7 lol.It has Game Mode that is supposed to increase performance in games etc seen some GTA5 results and they look promising.
Bios 1.2 official
sry scramz i thought we resolved this for you in an other post maybe i dreamed this
Start at stock on the cpu then select a xmp and then set the volts to 1.35 manually and set the freq to 3200 manually then reboot it go's into a crazy post loop looks like its not worked but if you give it a few mins it will boot then once its done that post will post quicker each time
in cpuz what does it say in the rank under spd
and what does it say in aida spd
mine are single rank & DRAM Manufacturer Samsung
Sticks in slot 2 & 4
No good for me. I will wait for the next bios update.
Bios 1.2 official
Its different RAM to yours I just noticed.![]()
Would I run into issues if I used 2x8GB sticks from a 4x8GB pack?
Ah yep you have the c16 i am on c14 ...but there still samsung you have and what rank single or dual will tell you under cpuz under spd
Re 2x 4 x should not really matter just try 2x 8gb 1st as this is the most compatible with ryzen as of now that will be your best bet
It says on AIDA Scramz is "2 rank" where as yours is "1 rank" under module size
Dual ranks?
Ah thx missed that ...that will be the issue then Scramz ...i am sure it will be resolved with bios updates one would hope so
So as I am stuck at 2660Mhz what kind of timings should I be going for, currently on 13-13-13-34.
good timings at that speed
So should I keep lowering them until the PC wont boot?
No harm in it
I have not had time to see if i can get lower timings @3200 but i am hoping to soon just need my pc's stable for work but i will find time to tinker soon
Well the bios is 13-13-13-34 but not in Windows...
I will try and lower again.
Seems the lower timings pushes the cache up faster, but Mhz pushes memory read writes.
What role do timings play with regards to ram.
I understand Mhz... more is faster but timings?![]()
i am no expert but some one will be here soon with a analogy ..the tighter the trimmings the faster it accesses less time to do so
More Mhz isnt faster if the timings are really bad.
