Matt should I pstate overclock or multi overclock?Testing out my 1800X @4.125Ghz using x4 GPUs in BF4 DX11.
For you cpu to downclock during low power states to you have to be overclocking using Pstates? Mine doesn't downclock but I'm using multi overclocking
AMD's power plan sorts out issues wrongly attributed to the scheduler (it's to do with the way W10 'parks' cores) and give performance improvement of around 3-20% in games (most in 5-10% bracket): http://www.legitreviews.com/amd-ryzen-balanced-power-plan-benchmarked_193344 . That's a heck of an improvement for a simple fix.New Ryzen Balanced Power Plan for Windows 10: https://community.amd.com/community/gaming/blog/2017/04/06/amd-ryzen-community-update-3
Or you could've just run on High Performance mode, but I guess this saves power compared to doing that so it's a nice improvement. Hopefully Microsoft will incorporate those changes into the OS itself at some point.AMD's power plan sorts out issues wrongly attributed to the scheduler (it's to do with the way W10 'parks' cores) and give performance improvement of around 3-20% in games (most in 5-10% bracket): http://www.legitreviews.com/amd-ryzen-balanced-power-plan-benchmarked_193344 . That's a heck of an improvement for a simple fix.
No point for Microsoft if AMD is going to add it to their chipset drivers package soonOr you could've just run on High Performance mode, but I guess this saves power compared to doing that so it's a nice improvement. Hopefully Microsoft will incorporate those changes into the OS itself at some point.
Unfortunately for myself (and some others I've seen on Reddit) this isn't working for me, in that after I install it it just doesn't show up as an available Power Plan, although it does show in the Provisioning Package list. For now I guess I'll just keep switching back and forth between Balanced and Performance with a couple batch files I have on my Desktop.
Restart?
Is there really much of an advantage using the Ryzen power plan compared to the high performance power plan? The AMD blog shows the biggest gains are generally when using the high performance plan which we were using anyway?
You'll be using a lot more power on high performance mode. So if your games are all running at over 60fps minimums and your monitor is 60Hz there's no benefit.
