Yes, I did. Thanks for correction. (Busy trying to get product updates on my QA website on the second data centre lol... it ain't playing ball and am quickly typing whilst I wait for it).
Honestly I don't want to recommend a particular one, because it has been shown time and time again that manufacturers keep changing the chips memory and don't let the consumer know. I'm sure some of the guys can here can recommend a particular model. Also, look here: https://www.reddit.com/r/Amd/commen...bdie_confusion_eg_on/?st=j0zuwh6g&sh=2ac3529a
P.s. try to get a quad kit instead of two duals, that way you can ensure you are getting the same chips and it is a matched set. (plus it might be slightly cheaper for the quad kit)
Ok thank you
