Ryzen balanced power plan tested:
http://www.legitreviews.com/amd-ryzen-balanced-power-plan-benchmarked_193344
Installed it the other day, it's better than default balanced but still not as good as high performance.
Ridiculous results. 4% slower at 1440p and 10% slower at 1080p (with their particular test suite of course) but for nearly half the cost and with a better stock cooler. The advantage of cheaper motherboards are probably counteracted by the greater need for faster RAM though. Also bear in mind that the i7-7700K has a bit more overclocking headroom too. Having said that, this doesn't even touch on the fact that there's an even cheaper R5 1400 which will probably clock just as well as the R5 1500X. Why would anyone buy an i7-7700K now unless they literally didn't care about money?TechPowerUp for 1500X review. 10% slower overall compared to 7700K at 1080p Gaming.
https://www.techpowerup.com/reviews/AMD/Ryzen_5_1500X/19.html
Intel has the gall to ask $189 for the dual-core i3-7350K with unlocked multiplier, and half the L3 cache.
All that, the stock cooler will easily handle the 1500X at 4Ghz overclocks, so less money saved yet again! It's a cheaper overall platform, where more money can be spent of a GPU.
As TechPowerUp says in their conclusion:
"Intel has the gall to ask $189 for the dual-core i3-7350K with unlocked multiplier, and half the L3 cache."
AdoredTV
Sanity check me if you would please chaps... single thread Ryzen performance @ 3.9-4.0: not going to be WORSE than my 2500k @ 4.2, is it?
(I have some things that only use one core and I want them not to get any slower if I switch.)
Also, we're sure the AM4 boards will be compatible with the next wave of Zen? I'll be happier buying into it if I know there's an upgrade path available![]()
Not 100% But I'm going to safely say yes, IPC is better. I haven't even overclocked my 1700 and it's faster than my 3570k was at 4.4Ghz in games.
Plus AMD have said AM4 will be around for another 2-3 generations of Ryzen so unless something drastically changes (big promise broken) then yes AM4 is around for another 3 years.
Not slower in the slightest! It has 7% less IPC than intel Kaby-Lake.
Even then a 4Ghz 1700 is 7% slower than the 5Ghz 7700K in gaming. These tests are even before Ryzen got game patches. Like in Ashes where a patch added 31% extra performance for AMD there, and Total War got another 10%.
Even in FO4 which is one of the lower performing games for Ryzen,its faster than SB.
Excellent news, thanks peeps! I figured it only needed to have 5% better IPC to not be a downgrade in any circumstances. If it's an all around upgrade, then that's even better
(I know it's low OC for a 2500k, but I think driving 32gb of memory is a problem. Lots of memory controller voltage to get the ram happy makes for a very hot chip!)
