Yeah. Price is only thing holding me back. This thing will deprecate like crazy over the next 24 months. I have to be patient. It will likely take 24 months for it to drop to my price range. By then the tech will be more mature, come with HDR, 120hz and with adaptive sync tech.i think i would be sold if this was about half the price...
i wonder if 55" is too big for a monitor - the LG c6 seems to be around a sensible ish price considering the size.
OLED Monitor Quality and Pixel Policy
During the OLED monitor manufacturing process, it is not uncommon for one or more pixels to become fixed in an unchanging state which are hard to see and do not affect the display quality or usability. For more information on OLED Monitor Pixel Policy, see Dell support site at: http://www.dell.com/support/monitors
Common Symptoms: Missing Pixels
What You Experience: screen has spots
Possible Solutions:
• Cycle power on-off.
• Pixel that is permanently off is a natural defect that can occur in current display technology.
• For more information on Dell Monitor Quality and Pixel Policy, see Dell Support site at: http://www.dell.com/support/monitors
Common Symptoms: Image retention from a static image left on the monitor for a long period of time
What You Experience: Faint shadow from the static image displayed appears on the screen
Possible Solutions:
• Use the Power Management feature to turn off the monitor at all times when not in use (for more information, see Power Management Modes).
• Alternatively, use a dynamically changing screen saver.
Umm unless screensaver is all what you will display on the monitor? Otherwise you will get burn in from window caption bars.If they made it cheaper I would be more than happy to use a screen saver.
Huh? I though a screensaver was something that would turn on after a certain amount of time of inactivity. Like we used to use on CRT monitors. What does task bar have anything to do with it?Umm unless screensaver is all what you will display on the monitor? Otherwise you will get burn in from window caption bars.
Unless you
a) make taskbar autohide
b) don't use maximized windows and keep remembering to move your windows around
d) regularly change wallpaper
This sounds like a lot of hassle for "premium end monitor". I buy monitor to use it, not to think that I am wearing down some pixels too much because I forgotten to regularly switch where Messenger displays its popups.
Well, or just never use monitor for desktop (e.g use second LCD one for that) and use OLED only for full-screen games/movie watching. Even then, you have to be careful not to use letterbox (will eventually burn in letterbox edges) or not to play single game all the time which has HUD in same place.
Screensaver turns on when you *don't use the monitor*. May as well just use "turn monitor off" option - this will stop the wear completely.Huh? I though a screensaver was something that would turn on after a certain amount of time of inactivity. Like we used to use on CRT monitors. What does task bar have anything to do with it?
I would even be happy to go as far as having my monitor go to sleep after a few minutes of inactivity.
Lets see what Vega reportsJust sat there using windows like I am now I have my taskbar showing and will do for 10 hrs a day. There isnt an inacivity to invoke a screensaver so 10 hrs of taskbar will burn in on a oled screen unless they do something clever.
I'll come back in a year.Lets see what Vega reports![]()
Good to know.Absolutely zero image retention on mine so far. But I do use the "auto hide taskbar" option.
Just popped back in here again to drool over these picks
OLED will definitely be my next monitor. Just need to wait until 2019 for a 4K 120Hz OLED with proper HDR to come out at a somewhat decent price![]()
Don't say that manSo 2025 for a "monitor" probably....![]()
LG 34" 2560x1080 144HZ gsync:
http://www.lg.com/us/monitors/lg-34UC89G-B-ultrawide-monitor
$999
Lol......![]()
Daniel has sent all our feedback to LG so he will make it happen.
