This isn't eco pro coasting. So that's this mystery solvedThat's just the standard behaviour in eco pro mode.
The coasting mode disengages the gearbox and drops Revs to idle like coasting in a manual. Consequently there is no charging mode whilst it happens.
Cheltenham? That's BMW Europes new "Exemplar" Dealership, the largest in Europe apparently
Thereby using fuel. Is this meant to be economicalWhat's the purpose?
Right, so when the eco pro dial just centres to the middle then? Mine did that too sometimes, but not as often. The satnav screen would often show this...
The satnav screen never shows that during normal driving once you are in eco pro mode. There are no indications that coasting is taking place on the nav screen, that's just a settings menu.
Feels like this is going to be another xs2man story changing saga, you gave it away when you said you had the charge icon appearing![]()
Is that with cruise set to 75? I've not seen over 48 so far, but my morning commute has 10 minutes of going up Birdlip hill which kills the economy!
Going to try it on the way home
He still appears to have had the only 2013 530d in the world which has coasting enabled from the factory though..
I go up at half 6 most mornings, I really wish I could go faster than the 50 most people seem to want to sit at. It's also yet another classic example of I'm going right so everyone sits in the right lane even though the left lane is clear and it's clearly signposted that both lanes go right. Then people seem confused when they try and cut across but there's cars there!I find the quicker you get up that hill, the better your MPG...![]()
I want coasting. Guess my DCT and monstrous V8 would make it pretty pointless.
Love how the crappy 120d car I had a few weeks back had power meters but mine don't work (when coded). Lame-o
The coasting is seemless I was reading an article that the next step is having stop/start kill the engine when coasting.
Perhaps as without the engine running there isn't enough power for the brake servo, power steering and other electrically powered gubbins that the 330e has vastly larger power reserves to power.My 330e does this and they call it 'sailing' instead (could be a US term). I assumed all other eco-pro + stop start cars did it, why wouldn't they?
