Yeah
I thought it was through and through a wheel cleaner but it definitely has iron removing properties.
Would probably be better using Iron X on the paint as I'm sure it would be higher concentrate etc.
Back to using the good old TDG Products today, this time on my own car. Truth be told it wasn't that dirty, but the front end was littered with dead bugs as always seems to happen this time of year. TDG Prewash made short work of that however.
I hadn't been using a tyre dressing for a while, and the tyres were filthy - I've started using TDG Wheel Cleaner with a foaming head, not sure I like it so might go back to a standard sprayer. The wheel cleaner is so cheap to use though, it costs around £1 a litre once diluted (bought as concentrate, dilutes down)
TDG Prewash after a few moments of dwelling, perfect thickness and only used 70ml of product to the rest of the 1L lance water. Only used around half of the lance too for the full car, wheels and arches.
And then after completing, tyres dressed with Megs Ultimate Tyre Dressing as fancied to change things up a bit
And because my post was quite TDG heavy, all the products used (went over with Juicy Details Iron Remover and Nanolex Tar Remover prior to applying the wheel sealant pictured and a mixture of Primal Details Wax and GTechniq C2V3)
