- 21 Apr 2013
Changed it from ACHI to IDE. Save and exit? Then re insert the usb?
Check that the first boot is USB still..
We're going for simple - it;s your brothers PC - and speed gains for AHCI would be negligible plus we can't update drives firmware (safely) and we've yet to ascertain that it's stable (checked its read/write etc with software)
Then threaten it with...
FFS work you silicon bitch!
I find it helps![]()
Format the biggest partition right?did you:
delete all partitions
new
format
install on largest partition.
but...I did that.
did you before?
If not - bad Beady!
Before we had the trouble of getting in to BIOS? Yeah I'm sure I did.but...
