You must have had those wheels fitted for all of 5 minutes.![]()
the supercharged Mustang sounds greatbloody loud too
Yes easily fastest thing I've being in once its gripping, relentless pull, 60-160 can't be far off 10s and yes its insanely loud as its running headers, its about to get louder as well as the owner has a valved exhaust coming so valves closed it quieter, but open even louder and deeper, because like me he agree's it got all a bit too raspy since headers, so he is sorting that.
Told him to try 60-100 in one gear, should be around 2.5s if he uses 3rd with no wheelspin. My old Mustang was 3.8s on 18" wheels in one gear and that was an insanely quick car as it was 600HP and around 1580kg, this thing makes that one slow.![]()
no idea about your finances m8, but i'd definitely get your car Supercharged.
yea the mustang has a sharp raspy sound, it's ok, but i prefer the deeper muscle car rumble, the Camaro has that similar raspy sound too.
It just down to exhaust setups.
Most Mustang runs X pipes, fitting a H pipe kills the rasp. I like mine how I have it, deep bellow and rumble at low RPM, AMG type rasp when on it.
My plan is not to keep this car, its not perfect for me. If I buy a Mustang to keep, it will be MY18 model, I want the modernised engine and 10-speed, then I can fit a Whipple or Pro Charger style setup and go for 800HP and be even quicker. My car is a manual and well I don't want a manual any more. Unless I just scrap that idea, sell the Mustang and M3, go buy myself an R8 V10 S-tronic as can get them for 70k now which I can afford to do.![]()
what about the Camaro (either of them) , because Ian Allan rang me up the other day.........it's beyond my budget but for you it's not
It's a shame the my18 model didn't improve the looks![]()
Reserving judgement on that until I see one in the flesh and after owners have had them.
the Camaro has dreadful visability, .
like all cars, the Mustang looks way better in real life.It's a shame the my18 model didn't improve the looks![]()
