Meanwhile, in GPU land...
Yeah, Polaris is primarily for Mobile, and console SoC, and is only efficient at low clocks.
Hopefully with Vega they have that all sorted
I wonder if hbcc would see games using more memory than they need too? Say yiu have a 16ghbm vega card and turn on hbcc you could see tombraider using 20gb of video memory usage at 4k max settings. That would keep kaap happy? Lol
That would be rather needless, unless they have something up their sleeve for it.
What's also interesting is how Vega Frontier matches up against NVIDIA's new Telsa V100.
~20% faster while not available until near end of the year, costing significantly more; and being dramatically larger.
~510mm2 vs 815mm2
It's also PCIe vs NVLINK; the V100 PCIe card will be slower than the NVLINK one, just like the P100 NVL was faster than the PCIe.
Never mind the V100 has a yield of 1 per 12" wafer; that cost will be massive, and supply low. Which is why NVIDIA were taking pre-orders already. It's essentially built to order.
Outside of NVIDIA's new Tensor Processors for mixed precision workloads, Vega actually looks really decent in comparison, especially given the size and R&D budget.
Same here! If it's 10% slower in averages, but has improved minimums over 1080Ti, I'll be very happy.
I look forward to reviews, especially in video work as well; AMD is already good there; and seeing the compute on Vega I hope to get a smashing card.
~510mm2 vs 815mm2
I said this many times but some people are too much in denial.
VEGA is more towards pro consumer market than gaming. AMD VEGA will not even properly beat GTX 1080 leave alone GTX 1080 TI in 95% of gaming titles.
If you bother about energy efficiency in GPU, please go buy the GTX1080Ti.Meanwhile, in GPU land...
The fuse on the router's power plug died yesterday, so I've not been able to get on the internet till now.
What did I miss? Is Vega coming in June? Is it good? Or are we doomed? (flicking through the past few pages of this thread it sounds like AMD showed off some non-gaming GPU instead?)
You realise the official line is the Titan X and Xp are also "deep learning/pro" cards, and therefore so is the 1080 Ti.
All there really is to it is how many Tflops does it have, and how efficiently can it utilise those Tflops.
Vega has 13+ Tflops (and also 26+ Tflops FP16, which can be used in niche cases), so it has the potential to be good.
The Titans have always been about gaming. Can we please drop this myth that nVidia marketed them as compute or workstation cards?Like above you do understand Vega has 7 GPUs plus Titan was once not seen has a Gaming GPU now its Nvidia top rated Gaming GPU, seeing the Ti is built on the same spec that is also not a gaming GPU then loool
As others have said. I am ready to take 10% less top fps numbers for mins that are 3x what the competition is able to do.
Been at work all night.
Am I right in thinking there is still no real news about gaming Vega cards.
Correct.
You work? I thought you was retired and living from your lottery winBeen at work all night.
