From what I see, I start the curving etc before I get to parallel So I could well believe I need to improve mobility.I'm not a master on form so other's will probably correct me. But it looks like your trying to go too low when you haven't got the mobility at the bottom. Your legs get ta s certain point then your bending your back/leaning forward to get the bar slightly lower.
This right here is paralysis by analysis.From what I see, I start the curving etc before I get to parallel So I could well believe I need to improve mobility.
Someone suggested stretching my hamstrings? as they could be short and affecting me.
I'm on the verge of finding someone to be there, the videos can only go so far, I might have to pay somebody haha
To add to this, if you pause the video at .29 while at parallel your back in straight. Not only did I forget my shoes for legs. I forgot my towel on a day which includes 10 rep squats and split squats. After this I'm going to look like a swamp monster.This right here is paralysis by analysis.
Sure, there's a little work to be done. There is for all of us. I've been at it for 8 years and I'm still learning. Put some more weight on and just keep at it. Your body will adapt and you'll begin to find the groove that suits you. For the record, empty bar lifts are pointless for assessing form. My form doesn't settle until I have some weight on.
So, trying to fix this damn squat form.
Sometimes, I feel I'm getting worse haha
Watching it myself, looks like I'm leaning forwards..... Dunno if I should be pushing my bum back more?
Goblets, no shoes, trying to not go deep etc
https://www.instagram.com/p/BUUEobXDfj4/?taken-by=blairloch
New 1RM on Front Squat - 130KG. Still have a bit more to give I think, only got a little bit sticky!
How are you finding the Romaleo 3s?
That's probably true - but they look much cooler than the older ones! Nike need to stop releasing great colourways on Metcon and Rom's because I only have so much budget for stuff I don't need!!Cool. I've seen people say they think they Rom 2's are more durable and these won't last as long with the upper being more like a trainer than a traditional WL'ing shoe but they certainly look the part.
