Wouldn't a rinse suffice?The clay mitt suspends the contamination from what I recall, making a second wash necessary. For the time it takes however, definitely worth it.
On a side note I bought two of the £1.99 B&M drying towels. Sure they probably won't dry 2 cars like £10 jobbies but I can dry the whole of my Impreza with one.![]()
Plus, the time it takes me to wash a car, majority of it is getting stuff out and putting it away
Probably. But I prefer to use something with cleaning agents to properly ensure the contamination is off the of the paint. With a waxed car, point a hose at it and see how much dirt it removes, a little but not a lot. Lets not forget once you've clayed there is absolutely no protection left on the car so the water isn't going to have any further help to removing the contamination from the surface.
It's probably over the top, but I get an enjoyment out of it allPlus, the time it takes me to wash a car, majority of it is getting stuff out and putting it away
Enjoyment I can't knock. However from my knowledge the contaminants should be stuck within the clay hence why only a rinse should be need to get any that fall out from the clay and rest on/within whatever's been used as a lubricant.
Considered fixing it?
Get in touch with nilfisk support, ive found them to always be fantastic.
If you want a new one I find the D130 fantastic.
i use a karcher k4 for the last few years with no problems .But the All Black 8 from directhoses is getting a lot of good reviews and is worth a look
Hi Chaps, thanks for the responses, I have had a look at it this afternoon, checked the fuse which tested out fine, so plugged it back in and it seems to have come back to life. Not sure what happened really, I used it to rinse down one of the cars yesterday and then came back to use it after I washed a section of it then nothing. Today it has behaved perfectly fine without issue. Strange.
Thanks for your suggestions though!
could have been a heat cutout.
Yip. Glad it's fixed. Your old work-horse lives on!
Any recommendations for a wax for black cars ?
It rained all week and the Turtle wax black box didn't last![]()
Bilt Hamber Double Speed Wax is quite cheap and lasts well, looks good on black. It's worth putting a coat of some polish under it, Bilt Hamber Cleanser Polish makes for a good base on black, then top it with the Double Speed Wax.
yup that is a pretty decent wax.. but one note, THIN application is key or you'll be struggling to buff it off.
also poor boys http://www.cleanyourcar.co.uk/wax/poorboys-black-wax/prod_1664.html
Cleaned up the headlights on my S2000 at the weekend and really chuffed with the outcome
Before:
After:
