Maybe consider just buying it as a TV only and not as monitor. Will keep you happy for 3 years until what you want comes out? If I was not super happy with my LG Plasma TV I would consider picking it up myself now to use as TV.
I also make use of my plasma only being 1080p as I can easily play certain games on it if my gpu is struggling at 4K on my monitor. Plus it is nice to play games like Street Fighter V on it and soon Tekken 7. My Nano will be able to deal with both those games maxed out easily to maintain a rock solid 60fps![]()
If you're very bothered about 3D movie watching, wait till VR headsets are about 10,000x5,000 (5000x5000 per eye) or above. That'll be around 4K TV quality, but REAL 3D. In that you'll actually be seeing 2 images at slightly different angles, as in real life.
Are we done with the monitor talk now? And other off topic talk.. its wasting my time and lots of others time having to skim through this thread.. jeez![]()
There is literally nothing to talk about yet anyway.![]()
for cs go on both monitors i turned freesync off with no frame limits, i seem to get on better with thisErrr ?!? I do now...
Not everyone suffers from lag, I don't think it bothers me but I haven't had a monitor past 5ms so I don't know for sure,
If lag isn't an issue iit'll be ideal for a game like CS:GO where you can easily keep the fps above 52 and in the Freesync range,
Do you have it capped to 75?
7nm, it's all marketing it won't be a true 7nm process. The 14nm/16nm Nvidia and AMD are using are just a 20nm process with Finfett transistors which somehow they can claim is 14/16nm.
Names aside (as X nm means nothing anymore) the IBM/GloFo process is expected to be just marginally better than Intel's 10nm (coming up now).
Vega HBM 2 8GB memory stack costs $160
http://www.fudzilla.com/news/graphics/43731-vega-hbm-2-8gb-memory-stack-cost-160
Only 6 days 23 hours, 54 minutes and 2 seconds until AMD's Computex Event!
Bring on Veeeega!
Actual cards could be another 6 months away yet.
Been spending too much time on wccft, you're starting to sound like their chat. How long before you start posting racist anti amd memes?![]()
Likely around $50-70. 8Gb for the 1080 at around 40-50?I tried to look up the costs of 11GB GDDR5X, but couldn't find anything.
There is also the interposer costs and the additional manufacturing steps required.
What most people don't seem to realize that each new fabrication node is increasing R&D costs by at least a factor of 5 so you can't really compare costs based on die size alone. The 471mm GP102 die costs many time more to produce than the Maxwell GM200 die that was around 600mm^2.I guess that might seem about right. Most people expecting Vega to cost more to make than a 1080 Ti. So if it's like ~$100 more per card, probably not too far off the mark.
Nvidia are certainly having a good time charging ~$700 for a 471 mm2 part without HBM.
Development costs are exploding
