if you have msi afterburner running that's the problem most likelyHas anyone had issues with aquasuite crashing on startup? I get the splashscreen then I get a generic windows 'aquasuite has stopped working' message.
Just to confirm I had the same problem and fixed it the same way.Yeah, it was an older version of RTSS causing it. I've updated to the latest beta (v7) of RTSS now and it's working![]()
Hey all,
I was just hoping for a bit of advice.
I've got 2 temp sensors, a PWM pump and 6 PWM fan.
I was hoping to get an Aquaero 5 LT , would this be up to running my setup?
thanks
I dont have this issue but about one in every ten boots I seem to have a "Laggy" pc , looking in the task manager then usually shows high cpu usage for the software, closing it instantly resolves the issue.Has anyone had issues with aquasuite crashing on startup? I get the splashscreen then I get a generic windows 'aquasuite has stopped working' message.
I had the same problem for the first time earlier this week. I uninstalled and reinstalled the software and it's not recurred yet although it's only been a few days.I dont have this issue but about one in every ten boots I seem to have a "Laggy" pc , looking in the task manager then usually shows high cpu usage for the software, closing it instantly resolves the issue.
little worrying...
Keep me informed sir .. maybe I should log a ticket with their support see if i can help them sort it for other people ...I had the same problem for the first time earlier this week. I uninstalled and reinstalled the software and it's not recurred yet although it's only been a few days.
There has been an update of the software (I had to manually download it)I had the same problem for the first time earlier this week. I uninstalled and reinstalled the software and it's not recurred yet although it's only been a few days.
Since doing so it seems more silky smooth and uses less cpu cycles now![]()
