What did you use to clean them up? Mine need doing really badly.
Also I'm sick of swirl marks. Best course of action to remove them? I'm going to be clashing my car at some point, have the clay just not the time ATM, so this will remove all my contaminants and wax.
Guessing I'd go my regular clean (magifoam soak then two bucket and mitt) clay the whole car, polish with a DA to get rid of swirl marks then wax?
Last time I waxed I done it by hand but I'm tempted to pick up a DA as polishing by hand looks to be a right PITA.
So a decent Da recommendation and pads for both polishing and waxing as well as a decent polish? It's for a black car too so a decent polish for black would be nice.
Used the Meguiars Headlight Restoration kit, liked the drill attachment concept for sanding discs etc so went with that. Top tip though is put masking tape down (low tack detailing tape if poss) and then duck tape over the top which will be much stronger against sanding disc etc. Did that after hearing of people going through the masking tape on their cars
As Havana said the CYC kits are good I got my DAS6 Pro from there, I use it with chemical guys hexlogic pads and so far have only used mezerna polishes but quite happy with them tbh
