well as its silver
#Armour Armor Piercing = pointless, no monsters have armour to penetrate
Thanks for you reply but according to someone on reddit they do have armor, they even went into the games XML's files and checked.
Quote from SweetSugarCub at reddit.
Armor piercing reduces the amount of armor on a monster when you attack, allowing more damage to come through. Note that armor is different from resistance.
Armor is a flat number reduction, while a monster's resistance will reduce your damage by a certain percentage.
Taking a look at the game's XML files, monsters' armor rating ranges from 0 (Harpy, Drowner) to 180 (Armored Arachas). These are just some sample data, maybe DLC monsters have more armor.
Hope this helps.
Edit: Ok, I took a quick look at the DLC files, the Shaelmar has the highest armor, 200.
Snippet:
Code:<!-- Sharley--> <ability name="mon_sharley"> <armor type="base" always_random="false" min="200" max="200" />
Source link
That's why I thought I ask here, since not sure of the different between the stats.
